メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
601回答 すべてを表示
Blank Screen after DC in Power Board Replacement
I have a mid-2012 macbook pro that was working fine except that the magsafe had to be wiggled to charge and it would really heat up sometimes. The power board was looking pretty beat up. So I bought a new DC in Power Board (made by Apple - identical to the old one) and replaced it per https://www.youtube.com/watch?v=hGHov4t3.... When I booted up, I would get the chime, keyboard would light, but blank screen. Apple logo on outside cover does not light and shining a light thru it does not show my login, so I conclude the backlight does not work. Tried NVRAM/PRAM and SMC resets multiple times w/out success. Tried closing the cover for a while and reopening it w/out success. Removed cover and redid all the connections and checked the cables w/ a magnifying glass to check for damage w/out success. Even replaced the original DC in Power Board and triple checked all connections w/out success. Also tried to hook up an external monitor but no success. Any ideas? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Probably component got knocked
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Could you be more specific?
さんによる
check for any missing smd component near display connector
さんによる
コメントを追加
Thanks. I was pretty careful when I removed the MB but attached is a pic of the area.
Do you see any damaged or missing SMDs?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
So after looking at my last comment I can see that it might appear to be confrontational. Honestly, I didn't mean it that way and am just trying to figure out the problem and would appreciate any insight.
さんによる
i don't have same board to compare with. if no picture on external monitor too, must be issue with display circuit.
さんによる
コメントを追加
回答を追加する
DIYer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 69
