メインコンテンツにスキップ
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
Quasar VCR isn’t working
When the VHS tape is in the VCR there’s a spinning sound/catching noise, and it doesn’t play the tape. It doesn’t rewind or forward either but ejecting the tape is fine.
Update (12/29/23)
This is the info on the back of the VCR.
Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi @eph23
Check if the drive belts are OK and not stretched or broken.
I can't find replacement belts for the VCR model online so if they are broken etc unless there's a part number on the belt itself (unlikely) you may have to purchase the service manual and check if there's a parts list in that, where the belt part number is shown so that you can search for it.
If the belts are OK then the service manual should help to find out what's wrong.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@jayeff Thank you so much!! I will look into that and thanks for the link to the manual. I really appreciate it!
さんによる
コメントを追加
回答を追加する
eph23 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 264
