Flash pops up but does not flash?
The flash pops up, but does not fire..
この質問は役に立ちましたか?
Mac, this could be caused by the sensor not realizing that the flash head is up. To see if that is the problem, place your camera into Auto mode and half-way depress the shutter in a situation where flash would be required. The Flash head should pop up. Release the shutter and after a while depress it half way again. The camera should make a clicking noise like it is going to release the flash head. If the flash position sensor is broken or malfunctioning it does not recognize that the flash is up, therefore it may not fire the flash since it assumes the light was down. Check for the switch inside your camera flash to make sure it is making contact appropriately. there is a great write-up about that on here. and some great information "remove the 2 screws from the front of the popup flash The rear plastic cover will the clip off.
Inside you will find a small switch on the right side of the flash unit when it pops up the switch should make, if it doesn't try shorting it with a small insulated item the try the camera in low light and see if if flashes.
To fix you need to remove the spring-screw from the other side then gently pry the bracket off, then just pull out the small white sleeve on the right hand side of the popup near the switch, this sleeve moves in slightly and will not make the switch on the popup flash.
Gently put the flash bracket onto the camera, be very gentle as the wires are very thin. You will see the white plastic bearing has 2 small clips which need to be through the hole on the bracket the pin which activates the switch will then be in the correct position." on here. Whatever you do, make sure you discharge the condenser, getting zapped on your camera could be a hair raising experience. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Yes that worked for my D70s. I managed to prize the little white plastic sleeve out till the sprung clips locked onto the flip up body with a tiny spade screw driver. Once it got level to the hole I slipped another little screw driver between it and the black flip up body. levering it out pivoting on the screw driver shaft and into the opposite inside of the white plastic sleeve.
このアンサーは役に立ちましたか?
I would add to the above that I inserted a paperclip (with a small 90 degree hook) into the sleeve and pulled it out until the clips engaged. My clips were weak so the tension of the wires pulled the sleeve back in. Again I pulled the sleeve out and this time inserted a small wedge (plastic fork prong) between the clips to keep them in place. So far so good. Thanks for the write up guys!
このアンサーは役に立ちましたか?
Thank you for the awesome write up! it gave me the courage to tackle the repair on my D5100.
このアンサーは役に立ちましたか?
I have a D3100, My flash pops up but does not fire, and when I put on a external flash it does not fire. I didn't see a spring on my pop up flash mechanism.
このアンサーは役に立ちましたか?
I have a Nikon d5500, Flash pops up but dosn't fire. when i set flash off camera takes picture but when iset auto flash camera doesn't take picture. In display i see a new hand symble with double first bracket both sides.
Nikon d3300 flash pops up but does not fire, camera sensor recognizes when flash is up, still does not fire and when it does, it’s a blow out here are examples of auto mode (first 4) and manual mode ( last 4) - https://flic.kr/s/aHsmCZyzQq
このアンサーは役に立ちましたか?
Are you able to fix the flash issue in your camera? I am also having the same issue with my camera. Please let me know.
I have nikon d5200. I too have the same issue that the flash pops up but does not fire.
but sometimes it fires. most of the time it does not. for example if i try to take 5 pictures in same lighting condition, the flash may fire once but for the next 4 attempts it may not fire.
このアンサーは役に立ちましたか?
I have same problem.how do you fix it?
過去 24時間: 5
過去 7 日: 28
過去 30 日: 115
今までの合計 40,036
2 件のコメント
How about D5200. My D5200 is having same problem. Is this going to fix my D5200 as well?
Anu Anick さんによる
I had this same problem in my Nikon 5200 so just used a heavy blower that these A.C. mechanics use to clean the camera and it is working again. Most probably there may be some dust issues which got cleaned with blower.
Camaal さんによる
