メインコンテンツにスキップ
MacBook Pro 16インチの解体情報と修理ガイドです。2019年11月に発売されました。モデル番号はA2141とEMC3347です。
Touch ID does not work after battery replacement
A few days ago I have replaced the battery in my Macbook following the guide on ifixit, which involved taking out the logic board.
Anyway, I assembled everything according to the guide and everything works well, the battery is also great. However, I have just noticed, that even though the power button works, the touch id does not:
Whenever I log into the account after starting the mac, I enter the password, and after some time whenever it goes to sleep I cannot open it with touch id. Additionally, touch ID stopped working with saved passwords in Safari.
Also, whenever I try to add a new fingerprint, I get following error, right after I click add fingerprint and enter the password:
So it does not even allow to put a finger on it. Anyone knows how I can solve this issue? Because power button works.
What I did so far:
  • Tried to reset NVRAM and SMC
  • Tried to add new fingerprint in Safe Mode
  • Visually inspected if the ribbon for touch id and power button is damaged (it is not)
  • Tried creating a new user and adding a fingerprint
  • Tried running Apple Diagnostics (Control+D on startup) - no hardware failures.
Anyone encountered it and knows about any possible solutions I can try?
Update (01/03/24)
Finally found some time to disassemble it, I reconnected everything, as you can see in the images (even though low quality but hopefully good enough), the touch ID does not work and touch id enrolment fails :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
While you noted you inspected the cable could you have missed the damage?
I would inspect the ribbon cable again for damage as well as double check the ZIF connector interface. Is the ribbon fully inserted and squarely? Did you flip the latch back down so the connection is firm? Did you damage the connector?
How about posting some clear images of the ribbon and the connector here so we can see things as well.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I will disassembly it fully again and send it in later. However, is it called the ZIF Connector and does it have a latch? Because if you look in ifixit's battery replacement guide, step 31 says it is a touch id, and from what I think it is slightly different than ZIF connector and therefore harder to damage.
さんによる
@nextedoff - Your right! It’s a press type in this system.
In either case one can mess up the connector.
さんによる
コメントを追加
Having same problem, only I allowed Genius bar to replace the bottom case and logic board/battery due to bad battery. Unfortunately, after an hour trip in each direction to Mac store, looks like I'll be heading back. Only Mac employees' internal software for Mac firmware can re-pair the touchid sensor to the logic board. This cannot be done unless you work for Mac, or happen to have access to their internal tools. hope this helps, though late.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Let me know if they mention what was the exact issue once they fix it for you, there's no official Apple Store and genius bar, only authorized resellers and they did not want to touch it as I replaced the battery myself.
P.S. I have only replaced the battery, I haven't replaced logic board or anything else, so even though I gave up, I am still unsure what caused it.
さんによる
Well I will suggest you to checkout the following: https://discussions.apple.com/thread/849...
さんによる
Hi @gtip... as mentioned above, this is a macbook, not an iphone, but either way this can only be done at the Apple Store or by sending in your machine according to research online and Apple Tech on phone. Unfortunately, I gotta go to store. Thanks for the feedback though.
P.S. to be clear, I already read the thread you posted before I posted my first comment, hence mentioning I was possibly late to helping others previous to me, but maybe not for someone new to this like me
さんによる
コメントを追加
回答を追加する
nextedoff さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 33
過去 30 日: 108
今までの合計 1,396
