メインコンテンツにスキップ
The eighth generation of the Mitsubishi Lancer.
50回答 すべてを表示
lights on the cluster flicker when I try to start it it all goes dead
I have a question hopefully some one can help me figure this out ! 2007 Mitsubishi galant the ignition was ok till now now I try to start it the lights on the cluster flicker the when I try to start it it all goes dead .the battery is fully charged don’t know where to start !! Does anyone had that problem with the ignition and knows how to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @michaelgiovanni
Looking at the images of the starting circuit and some of the cluster lights, it seems that the only common factor may be a faulty ignition switch.
Once the ignition is turned to the start position the starter motor should begin to turn over as it is basically direct wiring from the switch via the transmission switch to the starter.
(click on image)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michael Giovanni さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 4
今までの合計 15
