メインコンテンツにスキップ
Repair information for the HP EliteBook 840 G3. This Hewlett-Packard laptop is designed for enterprise usage.
20回答 すべてを表示
How I can install an operating system on my hard disk.
I wan install operating system
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@obsaili, I would suggest you not answer your own question with the exact same question then accept that answer as being the solution. When you do that it makes the rest of us think you've already got an answer so we ignore your original question.
If you don't think you're getting a fast enough response, perhaps you should call someone who is getting paid to do this instead of soliciting help from volunteers like most of us.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @obsaili
There are some ways.
Get a Thumbdrive 8GB or above
Find another PC and Download Create Windows Installation Media
Win 11
https://www.microsoft.com/software-downl...
Win 10
https://www.microsoft.com/en-us/software...
Run the tool and select USB option
Allow the USB Installation media to be created.
Plug in the USB installation media and Power ON the HP Laptop and keep pressing F9
Boot onto the USB Media
Allow the setup to be loaded
If you need to wipe the whole hard disk, just delete all partition.
and install on it.
Once windows setup is completed,
https://ftp.ext.hp.com/pub/caps-softpaq/...
Use HP Image Assistant (HPIA)
to download the correct drivers and bios update on your pc.
Run the tool and click Analyze
Allow for some time to capture system configuration
Select All List except HP Notification.
and
Click on this
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Obsa Ili さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 116
