メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年5月に発売されたXbox One S All Digital Edition(モデル番号1681)は、オリジナル版Xbox One S(2016年発売)の改訂版です。このモデルのXbox One SにはBlu-rayディスクドライブが搭載されておらず(そのため前面にディスクスロットはありません)、ダウンロードおよびストリーミング配信されるエンターテインメント専用となっています。
Graphics and performance maybe a graphics card. Issue
Somebody please tell me if theres something I can do to fix it. On every single game I have tested out the graphics look terrible. I hard reset it but logged back into my account I also soft reset it didn’t work but I changed instead of it being on auto detect I changed it to HDMI and the graphics looked a little bit better but still insanely laggy and I have an LG oled c1. When I switched it to hdmi it wouldn’t let me turn on VRR or auto low latency mode I found out without those 2 settings on my Xbox graphics look better and isn’t really that that laggy but without those 2 settings on my Xbox feels so delayed for some reason even tho my game isn’t delayed at all. Also without those 2 settings on my games look better but when I turned either one of the settings VRR or auto low latency mode the Xbox goes black for a few seconds then the UI and everything instantly becomes blurry.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Is there anyway to fix it without repairs or any way to make it smoother
さんによる
コメントを追加
1 件の回答
could be the hdmi retimer ic is going bad, it cant be a graphics card issue as the cpu and graphics are all 1 chip
このアンサーは役に立ちましたか?
スコア 0
17 件のコメント:
Alright I know consoles pretty well and some components but can u tell me what an HDMI retimer does also does It normally go bad on its own or from a fall something my Xbox never fell but I just want to know if it is normal to go bad and how does it work
さんによる
@dandandand65658 its a signal buffer ic and yes they can go bad without falling and can also be damaged by a damaged hdmi port
さんによる
Ok I have a Best buy geek squad subscription so should I put a sticky note that says HDMI retimer might have gone bad so they see it when they repair it? And how does an HDMI port damage it I checked my HDMI ports they look perfectly fine but things can happen on the inside and not outside
さんによる
@dandandand65658 usually damaged pins inside the port, i honestly wouldnt trust geek squad. im from the uk and have heard bad things about them. if you would like to find someone else in your area you could try here https://www.repairlegion.com/repair
さんによる
I found a repair shop 4.7 stars geek squad had 3.2 I see why people don't like geek. Can I send videos here of what I am experiencing with my Xbox.
さんによる
12件以上のコメントを表示
コメントを追加
回答を追加する
Dandan Dandan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 21
今までの合計 437
