メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
After replacement of screen and dock, display shows only blue stribes
Hello,
I dropped my Iphone 4 and it cracked, and in an attempt to change the front screen, I ruined the dock connector. I got a new screen and dock, and have replaced them both, but unfortunatly now I cant turn on my phone. The sounds go on when i turn it on, but the display shows only a black screen with one blue stribe in the middle.
I miss my phone, pls someone tell what could be wrong?
Thx, Louise, Denmark
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hi Louise,
It sounds like the LCD screen is damaged. Depending on the level of quality of replacement part it could have been faulty to begin with or you have damaged it during installation.
I would recommend taking the phone apart and inspecting the front assembly again. First check that the flex cables are not damaged (which i doubt they are in this instance).
Then check the back of the LCD screen - a common mistake is to screw the left most screw of the wifi EMI shield in too tightly. By doing this the screw puts allot of pressure on the top left of the back of the LCD screen and creates an indent - causing permanent damage to the LCD screen.
Please see this picture for a return we had where the customer had done just this.
http://db.tt/HGtXhrS2
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Malou86 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,882
