problem charging samsung galaxy A32
Try to connect the charger to the phone, but it doesn't register that it is connected, I have to play with it until starts charging. I have tried with different chargers, but keep having the same issue.
Hi @carlos15230
First use a strong light and a magnifying glass to check that there's no debris lodged in the charge port and that all the pins are straight and not bent, either of which which may be preventing a good electrical connection to the phone.
If there is debris lodged in the port enclosure, do not use a pin or probe to try and get it out as you may damage the pins or cause electrical problems in the phone, use a vacuum cleaner and see if using that removes it.
If the pins are bent or the port feels loose, it may be easier and cheaper to replace the charge port board rather than having to source a compatible USB-C connector and then solder it in as a replacement for the loose/damaged original port.
Here's a video that shows how to remove/replace the charge port board in the phone.
Search online for GH96-14158A to find suppliers that suit you best.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 33
