メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
No pressure contact next to battery connector
Description:
While attempting to resurrect/troubleshoot a broken/damaged used iPhone 4 GSM I just purchased (screen is blank), I noticed after removing the back panel and removing the battery connector there is no pressure contact present in this phone. The owner prior to me did have the front and back pane replaced with a color scheme set. Whether or not there ever was a pressure contact in this phone I am unsure.
Question:
So, my question for you guys is this: should there be a pressure contact present in this iPhone 4 GSM (A1332), if so, where do I get one? Thanks in advance for any direction with my above concerns.
Respectfully,
Brian Davis
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
My iPhone 4 has a Pressure contact, but i never took mine off, so i dont know what issues it causes when its not attached.
its apart of the antennae system that receives GSM RF's (if your AT&T) and Bluetooth.
if your looking to buy one: Here you Go
Don't think that just because you have great cell phone signal, you dont need that pressure contact. That piece also receives the Bluetooth radio frequency.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hmm...ok, thanks for your comments! (:
$20! That seems awfully high so I did some prowling on my own. I found one at a much more inexpensive price...about 20 x's cheaper (: here you go, for anyone else in the future needing one:
http://www.parts4repair.com/iphone-4-pre...
Sells for $1.33 (:
Respectfully,
Brian
さんによる
Hi, did you see any improvements after putting the contact?
さんによる
コメントを追加
回答を追加する
Birdmanbrian1 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 3,470
