メインコンテンツにスキップ
2018 MacBook Airのマイナーなリフレッシュモデルです。モデル番号 (A1932) とEMC番号 (3184)が2018年モデルと同じです。このモデルはTrueToneディスプレイと僅かにアップグレードされたバッテリーを搭載しています。
Identifying a near-CPU component in a 2019 MacBook air
I have a 2019 MacBook air brought into a local repair shop, who quoted over $1000 to fix it. The problem is apparently this component which has fallen off the motherboard- I brought it to a friend who is an electronics expert, and could not get it to flow, nor identify it. I was wondering if anyone here knows what this component (labeled "R47") could be? Attached are several images of the board, and it is a model A1932 13" MacBook Air.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
It's hard to tell from the pictures but it looks like the component failed and left its pads attached to the logic board. That's why it wasn't able to be soldered back on. Once a replacement is sourced, somebody skilled in electronics rework should be able to clean up the mounting pads on the logic board, and solder the new part on. @oldturkey03 's answer about sourcing parts should point you in the right direction.
I'm a bit worried that the attempt to reattach the old part damaged adjacent components on the board. Once you've sourced a replacement part, I would try to find a different local shop specializing in rework, and have them clean up the board / install the new part.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
It was probably me who may have damaged the board. I tried to resolder it first, which was a *mistake*. How does one find these local shops? Most of them seem to be certified apple resellers, i can't find many that aren't certified apple dealers and thus probably wary of doing this for me.
さんによる
Hard to say depending on where you live. Reddit could be a decent source. Another place to look would be small companies that do electronics / circuit board assembly, as they sometimes employ technicians who can do work like this.
さんによる
コメントを追加
最も参考になった回答
@gxhut that is reference designator L7290 which is a 0.47UH-20%-8.5A-0.035OHM inductor in a MHCI03020 package.
Sometimes those packages are hard to match but you can measure from solder pad to solder pad to find one that will fit. MY favorite suppliers are Digikey and Mouser and I am sure that those are in stock. Of course, you can purchase from wherever you can find it.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Grant Hutchinson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 184
