Buying iPhone 11 Pro battery
Hi
When I buy battery from ifixit will the battery capacity be at exactly 100%
Generally speaking yes the battery should be at 100% capacity (You will need to let it charge once you get it installed) but its is good to note that it may not display under your battery health. Being that its an 11 Pro you will get a notification that says not original battery but that doesn't stop it from performing as it should. Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 42
