メインコンテンツにスキップ
S20シリーズのGalaxy Sスマートフォン。AI搭載トリプルカメラ、Infinity Oディスプレイ、LTE、5G機能付きWiFi 6を搭載。新色6色で展開。
31回答 すべてを表示
No network after screen replacement on S20 FE 5G
I replaced my screen with the frame, but after I was done I had no service. After some research I found out that I had bought a new screen for a SM-G780F and not SM-G781B that it should. Everything else is working great. Could it be that the wrong screen is causing the issue? Is the antennas somehow built in with the frame? I have opened the phone up and gone trough my work, and everything seems to be where it´s suppose to be.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @fredrik56686
Don't know the phone but according to this parts supplier the antenna modules used, one is applicable to both models (GH96-13998A), and the other only to the 5G model (GH97-25615A).
Maybe worth checking again and check if they're both connected OK
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for your answer. I´ve only replaced the screen and frame and not the actual antenna. I opened up the phone to check the connectors and they are connected properly. Maybe the antenna itself got damaged when i originally droped the phone.
さんによる
@fredrik56686
Just suggested the antenna modules as the LCD display + digitizer used in the SM-G781B and the SM-G780F have the same Samsung part number so presumably they're the same.
Not so if you purchased the complete display assembly. For some reason the part numbers are different
Here's just one example for the Cloud Lavender model complete display assembly
SM-G781B and SM-G780F
さんによる
コメントを追加
回答を追加する
Fredrik さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 95
今までの合計 261
