メインコンテンツにスキップ
Repair information for Whirlpool dishwashers.
160回答 すべてを表示
Repair or replace? This is the question! :)
I have a Whirlpool dishwasher model WRIC 3C26 that worked well for over 4 years. After the warranty expired, it broke down, displaying error 15 and making strange noises. A repair service identified the problem as a faulty recirculation pump, costing around 160 USD for parts and labor. Here's a video wth the error: https://d.pr/v/F8TV5r
After some DIY troubleshooting, the machine now has different issues: it doesn't heat water and stops mid-cycle. Given its age and daily use, I'm unsure whether to repair it or buy a new one, considering the potential for other parts to fail soon. What's your opinion on this? Should I repair it or consider purchasing another one?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Considering the price of parts, and of a brand new dishwasher... I'd personally replace the dishwasher. You have to look at what you've spent/will spend on parts, vs price of a new one. If you're anywhere near the 50% mark... don't bother. Because if you end up having to replace another part that's over $100, then you've almost doubled your investment in it. BUT, if you are handy and can replace these parts yourself then it can be worth it. If that pump is $160 parts/labor... then the part itself is probably around the $60 range. However you've also mentioned it doesn't heat water and will stop mid-cycle. This can add even more to the bill for parts. Ultimately your call since is your money. Just compare price of parts to price of new machine.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
blueksy_c3 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 22
今までの合計 104
