メインコンテンツにスキップ
トヨタ・プリウスは、トヨタが設計したハイブリッド電気自動車である。2009年から2015年まで販売された3代目では、空気抵抗係数の低い新デザインのボディが採用された。
Solar panel on the roof dosen`t work
Hi. Got a "old" Prius 2012 (third generation) and having problem whit the solar panel on top that going to cool down the car while in a hot sommer day. last summer had problem that dosent work and was wondering any info or manuel to see the connetcons
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @knutknutse66571
Here are some images taken from the 2009-2015 Toyota Prius service manual showing the solar ventilation electrical wiring diagram that may help.
(click on images)
Also just verifying that you are allowing enough time for the solar powered ventilation system to start operating as shown in this video?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
wow that was fast XD
Yes given it some time and standing in direct sunlight to avoid any obstruction. not been a problem until now this summer. Will go through it today and see if I can find the error through the images
さんによる
@knutknutse66571
Good luck.
I also tried to find the location of L104 solar ventilation relay (see image #2) but it is not shown in any fuse box diagram that I found online for the model. Maybe they showed the fuse boxes for the models that didn't have the feature installed or it is installed somewhere else. idk.
Also apologies for the poor images, they were the best I could manage ;-(
Hover your cursor over the image and then click on the magnifying icon. When it opens, click on the image again to enlarge it further and see if that helps.
さんによる
no problem anyting helps ;)
Possibly found out that there must be something with the solar panel itself on the roof that stopped working since I can't find any direct faults. but someone who knows where those wires go without demolishing the whole roof. So I can check the voltage/watt on the solar panel produse any electrical current
さんによる
コメントを追加
回答を追加する
knut knutsen (Skullspirit) さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 22
今までの合計 622
