メインコンテンツにスキップ
iPad mini 5-モデルA2133のWi-Fi版のガイドです。2019年3月発売のiPad mini 5は、iPad mini 4の後継モデルです。
Digitizer not working after replacement
I bought a replacement Screen and digitizer The screen works great but the digitizer docent some spots don't register on the left and right in portrait mode and in regular mode I can't see ANY damage The connector looks good. Is there Something you have to cover or is it apple's prioritization
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
don't have the original screen but the old digitizer worked perfectly except it was cracked and the display
さんによる
コメントを追加
1 件の回答
最も参考になった回答
You didn't mention if you had cleaned the connector with some 90% or higher isopropyl alcohol, but other than that it looks to me as though you've covered pretty much all of the diagnostic bases.
At this point I would communicate with the seller of the replacement screen on the issues you're having with it and see about getting a replacement, especially given that you didn't have digitizer issues with the original screen.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
thanks I cleaned it am waiting for it to dry. let you know if it works.
さんによる
コメントを追加
回答を追加する
Alistair moran さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 157
