メインコンテンツにスキップ
Repair and additional information for the 2017 Frigidaire LGHB2869T* refrigerator, a full-sized, automatic defrost model without built-in or smart features. This page covers information for model numbers matching the pattern LGHB2869T*.
1回答 すべてを表示
The ice maker on the freezer works fine. The ice maker refrigerator.
The ice maker in the freezer works fine. The ice maker in the refrigerator will not draw water into the ice cube Tray. You can hear it cycling like is making ice. I have changed the filter. I have unplugged and replugged the refrigerator. I have turned the ice maker off with the button and turned it back off. What else can be Wrong.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
Frozen water in the tube or its clogged with gunk or kinked also check if its connected.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Is this something I can check myself and clean myself? I don't have the money for a repairman.
I tried Google Google it but can't seem to find anything. I'd be leaning towards the gunk because the other ice maker at the bottom works, the water dispenser works.
さんによる
yes pull out the fridge and behind wil be a tube make sure to turn off the water behind it before other wise it will go everywhere then check for clogs if there are none its inside and you may have to get a repair best of luck
さんによる
コメントを追加
回答を追加する
Kathleen Bauer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 56
