Washer stops 8 minutes before cycle is done
What would make my washer stop in 8 minutes from the end of the cycle will be water or out of balance
Hi @juliekelso
Is the Start/Pause button blinking when it stops and if so what colour is it when it blinks?
Here's the service manual that may help.
If the Start/Pause button is blinking go to p.45/176 to view how to interpret what error code the blinks are indicating. The error codes and the possible causes are shown on p.46/176 →p.49/176.
If it isn't blinking then go to p.5 to view rhe procedure tio access the diagnostic cycle and run the diagnostics tests to hopefully find out what's wrong.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 70
