メインコンテンツにスキップ
2015年10月26日にリリースされた第4世代のSurface Proタブレット。
Does the screen replacement come with the display cables?
As the title asks: does the screen replacement come with the display cables? I'm supposing / hoping so, as I inevitably damaged the screen during a battery swap, and also managed to snap one of the display cables. So: ideally the screen replacement comes with the display cables as well...?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hey there @davidaaltman!
If you're asking about the ifixit screen, then yes, it does appear to come with the display cables, as you will see if you flip to the second image in the attached link. There also appears to be a small connector, with no cables attached, at the bottom of the screen.
Also, according to a notice on the page, there are two different types of surface displays that are not compatible and the only way to tell them apart is to closely inspect that connector. I haven't ever done any repairs on a Surface, so I don't know if there is a cable that connects to that connector or if it interfaces directly with your motherboard. If there is a cable, and that one happens to be the one you damaged, then you may have to resort to looking on eBay to find that cable.
Hope this helps!
Replace a front panel glass digitizer screen compatible with the model 1724 v1.0 Microsoft Surface Pro 4 with a Samsung display.の画像
製品
Surface Pro 4 (1724 v1.0) Screen
$159.99
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks, @fixer85785! I might be missing the detail in the image to which you've linked - which is the item I was asking about, and I apologize for not linking it myself - as I only see the connector and not the cables. But I think maybe I'm misreading your statement and you're confirming that the screen has connectors in general, and I had more intended to ask if the purchase of the screen from ifixit supplied the cables.
Anyhow, thank you for the reply, the reminder about the pin difference, and the suggestion to pick some cables up from elsewhere; I believe I will do just that. Thanks!
さんによる
コメントを追加
回答を追加する
David A Altman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 121
