My laptop wont charge
I plug it in it blinks but wont charge or turn on.
What could be a problem?
@lovrogovor20599 you forgot to tell us what blinks and how many times it does blink.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 29
今までの合計 125
Try turning it on without the battery connected and see if it turns on. If it does you probably have a dead battery.
Andrei Niculae さんによる
