メインコンテンツにスキップ
The Nikon D3X is a 24.4-megapixel professional-grade full-frame digital single-lens reflex camera (DSLR) released by the Nikon Corporation in December 2008.
No image after taking the picture
My D3X has no image on the screen after taking pictures
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @nothreeputts
Can you view the pictures OK if you download them to a computer and look at them that way?
Can you view the camera's menu screens OK.
If the answers to the above two questions are yes and no then there may be a problem with the camera's LCD screen.
When trying to take a picture try shining a flashlight at an angle close to the screen and check if you can see any images of what you're trying to take a picture of. The image will be very faint so trying this in a darkened room may help to see it if it is there. If you can see it then there's a backlight problem with the LCD screen i.e. loose backlight power cable to the screen, faulty motherboard or more likely a faulty screen.
I cannot find a service manual for the D3X but here's the D3 service manual that may help to remove/replace the LCD screen.
The D3 and the D3X use the same LCD screen.
Search online for Nikon D3X LCD screen to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
nothreeputts さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 155
