メインコンテンツにスキップ
日産自動車が製造する自動車の修理ガイドとサポート
696回答 すべてを表示
Crank slow after driving
95 nissan ks24e after driving for a while switch engine off try to crank it drags real bad and want crank let it cool for a while it will drag but it will crank
Things I have done and changed:
New battery,cables and ends,ck timing chain slack that is fine and ck the timing that ok. Don't no what elks to do anyone have something I can try
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@donaldduckowens it looks like you are giving us your engine model :-) I is possible that this is an engine problem, but I would suggest that you check your starter. It is possible that this is a wore out start and it may just draw to many amps. Remember starters do not need to be replaced but can be rebuild. Either or, check the starter first. Oh yeah, please let us know your vehicle year and model.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Have changed the starter 3 times
2.4l 95 nissan
さんによる
@donaldduckowens Nissan what ? :-)
Have you checked the engine at all? How does it crank over when you pull the plugs? How well does it run/perform once it's started? I recommend a compression check as well as a leakdown test. Check your spark plug face and see how the engine burns its fuel.
さんによる
@donaldduckowens
Have you checked the voltage on the battery after the engine has stopped?
I realize that you have replaced the battery but if there's a problem with the alternator or the voltage regulator it may be that the battery isn't being recharged properly whilst driving and/or that it is "aiding" the alternator in supplying power to the ignition circuit whilst the engine is running.
With the engine running, check that there's 13.8V-14.5V DC on the battery terminals. If the voltage measurement is outside of these parameters there's a problem with either the alternator or the voltage regulator
Just something to eliminate if it isn't cranking properly but it does start.
さんによる
コメントを追加
回答を追加する
Donald “DUCK” Owens さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 7
今までの合計 25
