メインコンテンツにスキップ
マツダ販売会社による自動車およびトラックの修理ガイドおよびサポート。
284回答 すべてを表示
Mazda 121 Soho: Irregular Idling, switching off often. Sometimes lack
Mazda 121 Soho: Idling irregular and fluctuates. Rough idling. Switches off often. Idling Control Unit cleaned but no difference. Sometimes when pressing accellerator no fuel going through
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@thennow the most common reasons for that are
  • Air/Fuel mixture too lean
  • Air leakage
  • Fuel injection control malfunction
  • Low fuel line pressure
  • Low Intake air amount
  • Incorrect idle speed
  • ldle speed misadjustment
  • One or more spark plugs not firing
  • Low engine compression
  • Carbon deposit in injection body
Your brief description of issue would lead me to check the fuel supply. I am sure you have already checked your plugs to see if you are burning rich or lean. If not, do it. Remove the spark plug and look at the face. If it is oily etc. your engine might have worn rings, bad valves etc. If it looks really dry and burned with a white-spotted look it is because of your fuel mixture being to lean.
Check your fuel filter, your fuel pump and measure the fuel pressure. Make sure that your fuel injectors are functioning properly and are clean.Your engine may just not get enough fuel. To help you further, we need to know the exact model year and engine size.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi @thennow,
maybe also get the OBDII port scanned for any codes.
What is the year model of the vehicle as it seems its location can vary depending on year? Some are behind a panel on the steering column, others are behind a panel in the driver's side foot well wall
さんによる
コメントを追加
回答を追加する
Then&Now さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 23
今までの合計 99
