Battery Cell Replacement and where to buy
Is there any battery cell replacement tutorial? and where to buy the battery cell?
@amosdaniel94668 check this guide ASUS ROG G75VX-BHI7N11 Battery Replacement Batteries are readily avaialbel for your compur but remember that shipping might be an issue if you are not in the USA. A lot of companies do not ship lithium ion batteries. Of course you can always check places like this
Now to rebuild the battery, is a different story. There are no guides for that. Essentially you need to do that like you rebuild any other battery. The problem with these batteries is that you can't easily open the case. Those almost always crack and get deformed to the point of no longer closing or even fitting.
There are some generic YT videos that show the basics but it will be different for your specific battery,
このアンサーは役に立ちましたか?
このアンサーは役に立ちましたか?
@ffixitwell agreed. I do not like to mess with the pouch batteries. I have rebuild plenty of laptop and other batteries that use the individual cells. Thus far never had a single issue with any of those. Using common sense can usually keep you out of trouble.
thank you for your answer guys.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 52
