My phone is restarting again and again and become too hot
Try booting the phone to the safe mode.
Use the phone in safe mode for some time. Note that most apps won't be accessible in safe mode. If the issue disappears it's a software problem. To fix it, do following.
If the issue persists in safe mode the battery is most likely at fault. Replacing battery requires specialized equipment so I'd suggest you search for a professional repair shop in your area to do it for you.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 14
