メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Getting the LCD back in casing
So I just replaced the LCD on an IPOD 4g everything turned out great. The lcd and everything is working fine im just having trouble getting the screen entirely into the casing. I dont wanna force it to much because I dont wanna crack the LCD because its very thin. I feel like when I try to push the bottom of the screen in the top pops out anyone have any tips on this. Thanks in advance :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
I cant figure this out I even took out the metal plating and put the LCD on top and it still doesnt seem to wanna fit in there correctly.
さんによる
コメントを追加
1 件の回答
ベストアンサー
I would lay it down flat on a table face down to make sure the casing wasn't bent then the other two things I would check are that the little speaker assembly at the bottom of the unit is put properly under the lip and second that the metal piece that is affixed to the top of the digitizer is placed correctly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Arron Mayers さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 544
