メインコンテンツにスキップ
Repair guides and disassembly information for Asus Republic of Gamers laptops.
355回答 すべてを表示
Asus ROG Strix FX753VD motherboard heatsink screw and nut sizes
Hi, I've bought a faulty laptop that was said to be overheating. the fan outlet was blocked with dust so cleared it out which improved things but it still overheats 30 seconds after starting a game.
After removing heatsink found a screw under the heatsink on one of the gpu memory chips which wouldn't allow the copper to touch the gpu fully. So when to refit and realised the person had tried to screw the the sink down that hard it broke 2 of the standoffs from the motherboard so i can't screw the heatsink back down.
Only hope is getting a long screw throught the motherboard and a nut on the end to hold the heatsink to the board if that makes sense. Picture 1 is the screw sitting next to the heat pad, picture 2 is the broken standoff, picture 3 is the hole in the motherboard i'll have to try to secure the heatsink down to.
So any idea where i can get a long screw and a nut to go on the end to hold the heatsink down?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@pinhead43530 the concern here is that if the screws get over torqued they may crack the motherboard next. If you still have the stanoff I would consider a 2 part epoxy to reattach them to the board.
If that is not an option for you, consider creating something like a U-shaped. Basically two screws (diameter small enough to fit through the holes) long enough to reach through the board and the heatsink, connected via a bar between the two screws(non-ferrous would be desirable). This should distribute any torque more evenly over a larger area.
Can it be done? Yes, absolutely. Just think a bit outside the box to ensure a safe reassembly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
pinhead さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 40
