Laptop is running slow ,memory usage is less how to fix
Laptop takes lot of time to get started when switch on and it takes more time to open an application , laptop is very slow how do I fix it
You don't say what operating system you are using. If it is Windows do a full Antivirus scan.
Settings > Update & Security > Windows Security > Open Windows Security
On the other hand you may just have too many applications loading during the boot-up process and also running in the background once you are booted up.
MSconfig to the rescue:
このアンサーは役に立ちましたか?
Clean out the inside of the computer and redo thermal paste. Use and application like CleanMyMac or cCleaner to clean off unnecessary files. Do a virus scan. Reseat the RAM. Defragment the hard drive.
If you want an upgrade to stop this slowdown later, try upgrading to an SSD instead of an HDD.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 40
