Battery dameged how I fix it?
Hi Hab,
What do you mean by the battery is damaged?
Is there any physical damage or is it just not holding a charge?
In both instances, you will most likely have to replace the battery.
If you tell me the Device's serial number or other precise identifier, I will be able to find you a replacement.
Hope this helps, let me know if you have any other questions : )
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 132
