Original DS Broken in half how could I fix it?
I know where to buy the shell cause but idk what or where to buy everything else
I'd start by disassembling both halves and seeing what's still intact. Obviously anything running through the hinge has to be replaced (two ribbon cables and a wire as far as I can tell). I can't tell what they connect to, but they should be easy enough to find once you figure that out. If you need help ID'ing anything, post a pic or two, we'll be here
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 55
