Charge port is loose
Wont charge without messing with charger
@michaelcorella you can try and replace it which will require soldering as well as trying to hunt for a new connector. OR, you could just change the charging board, something like thisThe cost for the board is around USD $10.
Since iFixit does not yet have a guide for this, use the one from here
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 44
