メインコンテンツにスキップ
A mid-range smartphone from Samsung released in 2019.
My phone won't charged after it falls off the ground
About charge of the phone
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@feruu could be a damaged battery but that is less likely. What is more common is either a damaged charging board or a torn, disconnected flex cable (charging board to main board).
Use something like this guide Samsung Galaxy A50 Battery Replacement to work on it. Step 16 in this guide shows the charging board and the flex cables. Here is a guide specific for the charging board replacement Check for any damage, torn or loose cables.
If you have any issues identifying things, you can always post some images of what you find with your Question. That way we can see what you see. iFixitでの質問に画像を追加する方法
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Samsung Galaxy A50 Batteryの画像
ガイド
難易度:
難しい
45 minutes - 2 hours
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Feruu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 42
