How to upgrade the memory and which ssd card is best?
What type of memory best suits the surface pro 9?
The SSD can be replaced by removing the back cover and replacing it with a compatible M.2 NVMe 2230 SSD. As long as it is M.2 NVMe, and 2230 (the physical size) I expect it to work in the Surface Pro 9 as this was a key feature allowing the SSD to be replaced with ease.
The memory (RAM) is not user-replaceable.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 68
今までの合計 371
1件のコメント
The Surface 9 Pro is available is several configurations. Can you provide the specifications for your model?
DKenn さんによる
