メインコンテンツにスキップ
The Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems, such as sensors, receivers, and other electronic components.
Flipper Zero. Stripped the screws a bit. What do I do?
I used a small metal screwdriver when trying to replace the housing shell and I think that it was stripped a little, but not as much. I don’t want to continue to try to unscrew it with the risk of completely stripping it. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
If you are un-screwing, usually the problem is using too big or too small of a screwdriver. Get the size that is big as possible that fits and press in as hard as possible when unscrewing. I don't yet have a flipper, so I can't recommend a screwdriver. ( but plan to buy one soon, such an amazing device)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The proper size is PH0
さんによる
コメントを追加
First get the screw out and take them into a hardware store or electronics parts place and have them get you placements and then reinstall using the proper sized screwdriver
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try soldering iron and twist with your screw driver
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
KingCool さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 30
今までの合計 435
