メインコンテンツにスキップ
Televisions made by the Chinese multinational electronics company, TCL.
264回答 すべてを表示
I can see the TCL start screen for a split second
Jeesh.... Im sitting here with a 65" 65S4 TCL. 4k. Only thing is I DONT see any backlight when I shine a light on a dark spot for a minute. But when I turn on, I can see the TCL start screen for a split second then it goes away. Not sure what to do. My TV is on the floor upside down with the back-off.
I was thinking about replacing the battery. But now I think about it that makes ZERO sense considering it works and turns on and everything lol. So I'll buy new lights uhhhhhg....
BTW, I bought a Black Friday deal on a Samsung 4k UHD Crystal 65" on sale for $400 from $900. HIGHLY recommend this one as the difference in picture quality is night and day.
I'm gunna go to BBB as well as the other person. Bc they r right- this is rediculous. We never have these long and they just DIE! These r sooooo expensive man! Come on u can do better TCL!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
@tysalminen I am a bit confused by this:"Only thing is I DONT see any backlight when I shine a light on a dark spot for a minute". You can't see the backlight but should see the screen ie. Splashscreen, Menu or whatever else your screen should display. This" the TCL start screen for a split second" is usually a pretty good indication that it is your backlight array that has failed. If you can't see any shapes, silhouettes etc. then it is possible that this is a main board (worst case scenario a panel issue). Remove the back cover from your TV and post a picture of all of your boards. Arm yourself with a multimeter and let's figure out where we can measure the voltages for your back lights as well as the voltages controlled by your main board.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had a 55” TCL break 3 years ago. Can’t believe 3 years later & I see the same complaints…
I could see very faint shadows on my screen. You don’t have to be in a completely dark room to see this. But you def won't see it in a sunlit room. I don’t have a volt meter nor know how to read one. I am good w/replacing hardware/electronics. I took an educated guess that my problem was the cheap LED backlight strips. Fixed it & 3 years later this month and my tv is still running! Here is my long story - may not work to everyone. Good luck!
The sound is working but The screen is black.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ty Salminen さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 29
今までの合計 93
