TV late starte. Give some help
TV late start and initiate screen not seen.
@radheshyam42855 "TV late start and initiate screen not seen." clarify this by giving us more history. LAte stat cold mean it takes some time to turn on. That could be an issue with the power board or the main board. So could be the no picture situation.
First, let us know what model your TV is. You picked the Sony KDL50W800C but we need to make sure. After that, unplug the TV and remove the back cover. Now take a look at the individual boards. Check for missing, charred looking components or burned traces. Check the heatsinks on the power board. I would suspect some MOSFET (as well as bad capacitors) being the cause for that. Post some good pictures of all of your boards with your Question, that way we can see what you see.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 10
