How can I change the battery?
I want to increase the time of working with my Acer Iconia Tab A500. So i want to replace the battery with one which has more capacity. Is it possible to do that? How can i do that?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
can you replace the battery? Yes. Can you put a bigger one in it? No.
このアンサーは役に立ちましたか?
O.K., so i have to live with the battery, which acer build in.
I`m afraid you cannot do it by your self but you are confident enough about your technical skills then you may can do this otherwise order a new replacement battery online and either replace it using some YouTube tutorials or alternately you can take it some hardware related shop.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,126
