メインコンテンツにスキップ
Sonyのワイヤレスノイズキャンセリングオーバーイヤーヘッドホン「WH-1000XM4」の修理・分解情報です。
20回答 すべてを表示
No sound from the left side.
Hello, I bought Sony WH-1000XM4 headphones in unknown condition. It turned out that the right side, the speaker and the touch panel were fully functional. On the left side, the buttons, NFC and indicator light work. The only biggest problem is that there's no sound from the left speaker. I tried to connect to the computer via aux and again, sound could only be heard from the right side. What could be causing this problem? I would be very grateful for your answer.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hi,
I've had the same thing happen to my headphones. What I did was I wiggled the left earpiece around until the right sound turned on; It would only turn on if it was placed in a specific way so every time I use them i need to wiggle it. If you want to fix it permanently, you could try opening the left ear cup and checking if anything is disconnected, because that is usually the problem. Hope I helped!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I opened it and checked if anything is disconnected before that and no, everything seems to be alright.
さんによる
Im not sure then. Sorry.
さんによる
コメントを追加
try diffrent songs or sound tracks and see if there is a change.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
thezoneofcum さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 25
過去 30 日: 81
今までの合計 1,401
