Replacement SMD component for the g14.
I'm looking for a replacement SMD component that is marked 8KB 2N, any one kniw what this is?
I found this but not sure if that is correct:
EM6K1-G-T2R
I have attached a picture of it:
この質問は役に立ちましたか?
EM6K1-G-T2R
この質問は役に立ちましたか?
Hi @andy45292
Here are the boardview and schematic files for the motherboard that will help to confirm what component it is.
Use the boardview file to locate the component to find out its circuit designation e.g. Q????? on the motherboard and then once you know that, use the search function (Ctrl + f) to find the component designation in the schematics to find out what type and model component it is.
Note: I'm not sure if the search function works when viewing in the ifixit pdf viewer, so download the file and view it in your browser and use the search function there
このアンサーは役に立ちましたか?
Any chance you have these for the 2020 model g14?
Actually, I was being dumb. this is already what I was looking for.
Any chance you know what L4502 is. Looks to be an inductor, but it only lists 120 ohm resistance for specs.
What is the make and model number of the motherboard or laptop?
The schematic linked above is for an Asus GA401lH
Looking at the schematic posted above there's no component with a designation of 4502, regardless of whether it is a Capacitor, Resistor or Inductor etc. shown in it
過去 24時間: 0
過去 7 日: 3
過去 30 日: 27
今までの合計 101
