メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
Black screen after replacing flex cable. [SOLVED]
[THE PROBLEM]
I ran into an issue in the shop where after replacing the Flex cable every screen I tried was black. The iPod wouldn't even beep when plugged in.
Since I googled the tar for a solution, and couldn,' find one, I'll post what I found for anyone else with the same problem who hasn't been able to find a solution.
The solution is moved below, to the answer so that it can be cleared per request.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Please use the last paragraph as an answer and accept it to clear the question.
さんによる
Thanks for letting me know guys, I did as you suggested.
さんによる
コメントを追加
1 件の回答
ベストアンサー
[HOW TO FIX IT]
I covered the circuits around the flex cable and de-solder it then cleaned up the pads and soldered on the new flex.
Not adhering to my own soldering instructions, of course I got in a rush and did this without de-soldering the + terminal on the battery first.
In my case, I went back and disconnected the + terminal on the battery and soldered it back on. The black screen went away and the iPod kicks up just fine.
I hope this helps fellow techs that may have found this.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Country Computer Service さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 11
今までの合計 3,304
