メインコンテンツにスキップ
How does this tiny piece fit back into the control switch?
Not knowing the play/pause/volume control was part of the earphone wiring and therefore not noticing that it was stuck to the packaging tape, the control's casing came apart when I took the tape off the packaging. A tiny strip of metal fell out and it seems to control the volume. (I was able to easily snap the 2 halves of the casing back together and the center button that forwards, etc still works)The very thin strip of metal is a little less in length than the inside of the control and about half the width, with one piece of metal about 1/16" square on each long side bent at a 90% angle. I suspect it fits inside the control switch somehow. Can I fix it myself? Is there a picture available of the inside of this switch?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Karen: If it broke when you took it out of the packaging from Apple, Call Apple and have them replace it under your warranty. Their number is 1-800-275-2273
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
great answer +
さんによる
コメントを追加
回答を追加する
Karen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 2,972
