メインコンテンツにスキップ
The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
20回答 すべてを表示
Why is my phone battery drain automatically
My phone was automatically draining. When I didn't use phone but also it's draining.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @jitu43737
When you are not using the phone but the phone is still turned on, turn off the following unless you need them on for some reason and check if the battery charge takes longer to dissipate.
Turn off WiFi and Bluetooth and also disable the internet connection by turning off the Data saver settings. Go to Settings → Connections → Data Usage → Data Saver.
Only turn them on when you need to use them and turn them off when you're finished.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jitu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 37
