メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
746回答 すべてを表示
Closing screen won't put to sleep?
Recently, Apple replaced my logic board, screen, and battery. Now, what I think is the reed switch that is activated by the screen closing is either not working or isn't connected properly. I did do a RAM upgrade once I got my mac back from the store. Could it have been me messing up something during the upgrade, or is it something else? I also found out that my optical drive doesn't work too.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I took it back to apple, and the guy who replaced the logic board apparently forgot to connect the reed switch to the logic board. They also put in a completely new optical drive, but it still wouldn't work. I just got a new logic board, and it works fine now! Thanks!
さんによる
コメントを追加
2件の回答
ベストアンサー
On different years they put the the magnets on different sides of the system (Obviously reed switches too.). Take a magnet along both sides of the screen when you find the magnet the magnet in your hand will react. Now slowly run the magnet down the opposite side of the uppercase (keyboard part), from where you found the magnet in the upper clam shell. If that puts it to sleep you found your problem. If the whole upper clam shell was replaced with a different year motherboard, that would explain the "why". Please let us know the results of this.
Please give us the last 3 characters of your serial number, so we can define your exact machine.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
The sleep/wake magnet probably fell out when they replaced your screen. Take it back to Apple and have them look into it. Have Apple replace your optical drive if it's still within warranty. If not, then buy a used one and replace it yourself.
Go into system preferences and select energy saver and adjust your settings to see if your laptop will go to sleep. Also, turn off your application called Caffeine, because that program inhibits sleep mode.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Austin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 3,729
