メインコンテンツにスキップ
Doest start completly and in few sec it restart repeatedly
It does't start completly but you can hear the fan and HD works only in a few sec , then it sart again same before no boot or display on screen... btw the screen is already broken but i used tv as external monitor (i mention it so you don't need to suggest that the monitor is the problem ) and it works without hustle.. The problem only occur after i clean up the fan. I remove the fan carefully and put it back just like i normaly do every time i clean it up.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Is a Keyboard issue. The power button is on a keyboard, and if he fail, the laptop don't boot up, and sometimes enter in a loop, because he thinks a power button is pressed
Try this My keyboard is not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Oh thanks. But i already figure it out. It just happen that i need to change thermal grease.. The termal grease just dried out and create over heating thst force my device to shut down..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alfred Addur さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 63
