メインコンテンツにスキップ
2021年に向けたAppleの最上位スマートフォン。9月24日に発売された「iPhone 13 Pro Max」は、6.7インチのProMotion OLEDディスプレイ、新しいトリプルリアカメラシステム、5G接続を搭載しています。iPhone 12 Pro Maxの後継機種。
74回答 すべてを表示
Why wont my iPhone charge? is it the battery? or is it the port?
My Iphone 13 pro max does not want to charge. It will not charge when plugged in and does not give any notification of accessary not supported. I charge it on a brand new apple brand charger and will not work. I was able to plug it in and get it to 55% but then when I picked it up it stopped charging and I tried to plug it back in and it refused to charge. The phone works fine when its on and the battery health in settings is in the normal range. Is my lightning port shot or is my battery fried? The only physical damage is the back of the phone is cracked up but that happened months before the issue with charging so I don't think it is the problem. any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Ryan,
The lightning port and the battery are both distinct possibilities, but there is a way to tell which it is. Try a wireless charger; if that works then you can eliminate the battery as the source of the problem, and if it does the same thing as the lightning port, then you can chalk the problem up to the battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ryan m さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 44
