I repaired my phone, and it is not charging after a month being off
So i had repaired my phone one month ago. For some reason, I had to turn it off and now when I'm turning on by charging. It is the same problem I faced. Not charging at all. circle is not moving. What should I do now?
What repair did you do?
Duck さんによる
@thequacker so appearently, the coil was the main problem, along with the charging port. because it was saying moisture detected. Even with all the problems, it was solved. I used it for a week. then my mom took it from me because it was my final. and now, when i tried to turn it on, it won't and the charging circle won't move, like before
Muntazir Pranto さんによる
@muntazirpranto "Even with all the problems, it was solved" how did you fix the initial issues? What repairs did you do?
oldturkey03 さんによる
