Samsung Ultrawide monitor LC49HG90 - Is it a T-Con problem?
Bad picture after turning on while 5-30 minutes. After that it goes well. This "warmup time" is longer and longer.
Here are all of the pics: https://photos.app.goo.gl/gDMsz4suDAaQmz...
Thanks!
4 件のコメント
I have same problem and i will try fix with new t-con board i think this is problem. I'll report the results when I replace it, which will be soon.
Mato Lukić さんによる
Unfortunately, the T-Con board did not solve my problem. I'll keep looking and write when I find it.
Mato Lukić さんによる
@matolukic The next best board level replacement to try would be the main board.
@andrasfodor suggested that it might be a COF issue, which would not be a DIY fix.
I've replaced my failing unit with an Acer EI491CR, which is a 1-to-1 match to the LC49HG90.
But, I still have the LC49HG90 in case someone actually finds a fix.
Steve Schlosnagle さんによる
I'm waiting for the second motherboard to arrive and then I'll try replacing it. If that solves my problem, then I'll start looking for the problem with the board I currently have.
Mato Lukić さんによる
