Windows 7 to upgrade windows 11
To upgrade from Windows 7 to Windows 11, you will need to perform a clean install of Windows 11. However, before you proceed with the installation, make sure that your computer meets the minimum system requirements for Windows 11. You can check the system requirements on the official Microsoft website 1.
Here are the steps to upgrade from Windows 7 to Windows 11:
Back up your data: Before you proceed with the installation, make sure that you back up all your important data to an external hard drive or cloud storage service.
Download the Windows 11 ISO file: You can download the Windows 11 ISO file from the official Microsoft website 1.
Create a bootable USB drive: Once you have downloaded the ISO file, you will need to create a bootable USB drive. You can use the Windows USB/DVD Download Tool to create a bootable USB drive 2.
Boot from the USB drive: Insert the bootable USB drive into your computer and restart your computer. Press the appropriate key to enter the boot menu (usually F12 or Esc) and select the USB drive as the boot device.
Install Windows 11: Follow the on-screen instructions to install Windows 11 on your computer.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 201
Hi @divyeshchi60871,
Please confirm the make and model number of the computer that you wish to update to Win11?
jayeff さんによる
لا يقبل اصدار جديد لا اعرف كيف
Zohir さんによる
