メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
Where are the "Power On Pads" for A1707, 2016
Hi,
Anyone know where the "Power On Pads" are for the A1707, 2016 model?
Are they the 2 square pads about 1/2-1" above/north of the Trackpad cable plug?
Also, does the keyboard need to be unplugged for the power-on-pads to work for this model?
Currently, the mbp is not turning on with the normal power button. Hence, why I wanna try the power-on-pads.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
As I recall, this is where they stopped featuring proper power on pads. There is a test point on the back of the board, which you could use, but I wager the easiest place to accomplish this is to use a resistor and a capacitor near the Touch ID and Audio connectors. This is on the same line as the Power On Pads from previous generations. It references SMC_ONOFF_L. This means it turns the System Management Controller on or off when the voltage is low (shorted to ground).
Short these two components together
The relevant Test Point—short it to any nearby ground
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thanks for the info!
I assume the 1st option requires removing the logic board to gain access to the “back of board”? (I wanna avoid disassembly)
So, is the 2nd option easier and viewable by just removing back cover?
So, just short it from that small circled red pad on bottom-right (from that 5x5 grid of pads) to a ground (upper mid right) with some sort of wire, correct?
Edit:
I have the back cover off, and I could not find anything similar at all (no 5x5 grid [next to edge/battery?]).
Looks like a completely diff pcb, esp comparing with components/layout around the round cut outs (fans?).
Perhaps it looks different from the back side, idk.
さんによる
@edgar27392 So I might have explained this in a weird order. The grid is indeed on the "bacK" of the back. The side that faces the keyboard when installed.
The One I would use is the one on the "front" side. So you don't have to take the board out. That would be the first image. There should be two itty bitty components right next to the audio and touch ID connectors.
さんによる
I’ve found it! (tiny cap & resistor)
It’s under the hinge-cover & touch-id-cover (T3 screws).
Looks easy! Thanks for your knowledge.
So, guess I gotta order a T3 driver (all my few computer tools are for 2013 & older macbooks - T5, T6, T8, P5, TR-1).
I’ll report back once I receive the T3 driver and try it!
Side note/comment:
Many people say in various threads, that sometimes disconnecting the batt-data-cable & main batt-power-connector solves the turning ON issue.
I tried it (I even left it disconnected for 1-2 hours), and it still doesn’t turn on, after I reconnected everything.
I also tried turning it on, while batt was still disconnected, but with the usb-c-charger plugged in (since some mentioned this turned it on as well)…. but, that didn’t work neither.
さんによる
So, perhaps something major happened within the logic board or the battery (some cells are def puffy).
Was working perfectly just a few days ago tho. Also, computer never has had any issues nor battery warnings.
Hope the power-on-pads (or, cap&res) works tho (once I get the T3 driver).
さんによる
コメントを追加
最も参考になった回答
@edgar27392 this is just to determine if there is a different way. @flannelist take a look on here. According to that, the debug for the power button is on the top side (keyboard side) of the board
but if you look closer at the schematic, SW5200 is actually on the bottom side of the board (PLACE_SIDE=BOTTOM). Pin 1 is bottom left Pin 3 bottom right, 2 top left and 4 top right.
Applying a simple jumper, like a paper clip or a flat tip screwdriver, and bridging 1/2 and 3/4 should accomplish the same thing. Please correct me if I am wrong here. Wouldn't be the first time :-)
このアンサーは役に立ちましたか?
スコア 1
16 件のコメント:
Nice work! I was looking at those too and wondering if they could do it.
I'll try bridging 1 > 2 and also 3 > 4 at the same time.
Edit:
Just tried it... no bueno.
Tried bridging/shorting 1>2 & 3>4 at same time with SS tweezers and surgical scissors.
Tried +10 times, also held for 10 secs. No response from computer at all.
(unless I bridged the wrong ones... but I def tried LowerLeft>UpperLeft and LR>UR)
さんによる
@edgar27392 seems to be an issue other than the power button :-) If your battery is "puffy" start with that. Replace it and let's start anew once it's in.
さんによる
@oldturkey03
I tried turning it on with battery and battery-data cables disconnected and usb-c-charger plugged in, but still didn't turn on. Would that rule out the battery?
さんによる
@edgar27392 it should, but I am of old school which teaches to repair/replace what's broken, then re-evaluate. All we know for sure right now is that your computer has a power issue. Wasn't there something with bad USB-C controllers on this model? Let me check on that to be sure. I am old so I have more frequent lapse in the synapse ¯|_(ツ)_/¯
さんによる
@oldturkey03 OoooooOOOO how did I not see those????? I definitely glanced right over them. Probably because I was looking at the boardview and not the schematic. But these would have been a much better bet than my nonsense.
@edgar27392 As for what the problem is. If batteries are slightly puffy. But you didn’t get any battery warnings and the fact that it doesn’t turn on even without power connected, this could be bad USB controllers. But it could also be a short circuit on the board. That could account for the swollen battery (though it could also be age). That’s still fixable, but you’ll need a multimeter to diagnose.
さんによる
11件以上のコメントを表示
コメントを追加
回答を追加する
Edgar さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 36
今までの合計 409
