メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
Home button works but digitizer doesn't
When I separated the screen from the phone, I used a plastic spudger as usual, and when I reassemble the screen, the touch stopped working.
However the home button still responds.
I inspected the wire for the digitizer and home button and it doesn't seem damaged in anyway.
What could've gone wrong?
I passed that spudger from the bottom of the phone to the top.
Is it possible that I severed or damaged only one part of that wire?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
totally possible (tiny unfortunate tear, not easily seen)
more likely and easy (enough) solution:
re-seat the connectors
pita remove front assembly, remove cables, re-snap them back on (I like a good click, then a sort of tiny swirl push, not as much as getting fingerprinted!)
then, before you re-double sided tape that back, turn on and test (front assembly does jot have to be glued back to work); if all well, then stick it back together!
hopefully makes sense, and good luck
(and if you fail, it may be possible for the genius bar (apple store), to backup without working digitizer)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex222 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 36
